I have noticed after installing the version 3.70-13 , in Settings → Integrations, I only see tank and temperature sensors and Relays under the physical I/O separator.
There is no I/O menu ?
hey @bradleydouglas that is strange, this is your system called “Test install”, right? Can you get it connected to internet and then enable Remote Support so we can check?
Hi , yes i can sorry for delay, some further feedback as well.
I will keep you updated on what triggers them to disappear
experiencing same issue on v3.65 - unplugging the IO extender USB cable and re-inserting it resolves the issue. I assume it will disappear again if i reboot….
Edit: I rebooted and the IO menu was still there. very strange. It seems unplugging and plugging the IO extender USB just once seems to have resolved it…
