I am in the process of doing a full clean update to v3.70~78 large. Flows have been refactored and save, Node-RED has been reset and disabled, VenusOS updated from v3.70~60 to v3.70~78 and finally Node-RED re-enabled.
As a first observation, before reloading flows, I find the following error message in the debug window, please advice what this means: (UPDATE, this seem to happen after importing additional node libraries with palette import such as boolean-logic-ultimate, but before importing actual flows)
msg : error
error
message: “Property ‘telemetryEnabled’ is read-only”
stack: string
Error: Property ‘telemetryEnabled’ is read-only
at Object.set (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/settings.js:83:19)
at Object.disable (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/telemetry/index.js:196:30)
at Object.updateUserSettings (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/api/settings.js:228:39)
at updateUserSettings (/usr/lib/node_modules/node-red/node_modules/@node-red/editor-api/lib/editor/settings.js:38:29)
at Layer.handle [as handle_request] (/usr/lib/node_modules/node-red/node_modules/express/lib/router/layer.js:95:5)
at next (/usr/lib/node_modules/node-red/node_modules/express/lib/router/route.js:149:13)
at /usr/lib/node_modules/node-red/node_modules/@node-red/editor-api/lib/auth/index.js:69:28
at complete (/usr/lib/node_modules/node-red/node_modules/passport/lib/middleware/authenticate.js:280:13)
at /usr/lib/node_modules/node-red/node_modules/passport/lib/middleware/authenticate.js:287:15
at pass (/usr/lib/node_modules/node-red/node_modules/passport/lib/authenticator.js:446:14)
