the fun begins with node-red , until it crashes ![]()
errors :
@4000000067d57be314c04374 15 Mar 14:08:41 - [info] Started flows
@4000000067d57c5203456cdc *** starting node-red-venus ***
@4000000067d57c52080aff84 *** Waiting for localsettings...
@4000000067d57c5209a15adc *** Starting in normal mode
@4000000067d57c58170516dc [info]: loading /data/home/nodered/.node-red/settings-venus.js failed
@4000000067d57c58178e828c [info]: loading /data/home/nodered/.node-red/settings-user.js failed
@4000000067d57c59263a23f4 15 Mar 14:10:39 - [info]
@4000000067d57c59263a4334
@4000000067d57c59263a471c Welcome to Node-RED
@4000000067d57c59263a4eec ===================
@4000000067d57c59263a56bc
@4000000067d57c5926a5bed4 15 Mar 14:10:39 - [info] Node-RED version: v3.1.13
@4000000067d57c592724706c 15 Mar 14:10:39 - [info] Node.js version: v20.12.2
@4000000067d57c59274d2264 15 Mar 14:10:39 - [info] Linux 5.10.109-venus-21 arm LE
@4000000067d57c5f07eb2efc 15 Mar 14:10:45 - [info] Loading palette nodes
@4000000067d57c7034edf31c 15 Mar 14:11:02 - [info] Dashboard version 3.6.5 started at /ui
@4000000067d57c753a842404 deviceInstance could not be assigned because res[1][0] is undefined :1.109/[object Object] (com.vic tronenergy.hub4)
@4000000067d57c76035562cc deviceInstance could not be assigned because res[1][0] is undefined :1.56/[object Object] (com.vict ronenergy.system)
@4000000067d57c76134b2bbc deviceInstance could not be assigned because res[1][0] is undefined :1.106/[object Object] (com.vic tronenergy.grid.socketcan_can0_vi0_uc436386)
@4000000067d57c761e5c4914 deviceInstance could not be assigned because res[1][0] is undefined :1.98/[object Object] (com.vict ronenergy.battery.socketcan_can0_vi0_uc339800)
@4000000067d57c76238423e4 deviceInstance could not be assigned because res[1][0] is undefined :1.114/[object Object] (com.vic tronenergy.packageManager)
@4000000067d57c7625ac5344 deviceInstance could not be assigned because res[1][0] is undefined :1.102/[object Object] (com.vic tronenergy.solarcharger.socketcan_can0_vi0_uc430181)
@4000000067d57c770a5e78ec 15 Mar 14:11:09 - [info] node-red-contrib-home-assistant-websocket v0.75.0 nodes initialized
@4000000067d57c7833c1ea84 15 Mar 14:11:10 - [info] Settings file : /usr/lib/node_modules/node-red/venus-settings.js
@4000000067d57c78342b954c 15 Mar 14:11:10 - [info] Context store : 'default' [module=memory]
@4000000067d57c7834aedac4 15 Mar 14:11:10 - [info] User directory : /data/home/nodered/.node-red
@4000000067d57c7834d42d74 15 Mar 14:11:10 - [warn] Projects disabled : editorTheme.projects.enabled=false
@4000000067d57c783552c79c 15 Mar 14:11:10 - [info] Flows file : /data/home/nodered/.node-red/flows.json
@4000000067d57c7906fffff4 15 Mar 14:11:11 - [info] Server now running at http://127.0.0.1:1880/
@4000000067d57c7909d6f584 15 Mar 14:11:11 - [warn]
@4000000067d57c7909d718ac
@4000000067d57c7909d71c94 ---------------------------------------------------------------------
@4000000067d57c7909d7284c Your flow credentials file is encrypted using a system-generated key.
@4000000067d57c7909d73404
@4000000067d57c7909d737ec If the system-generated key is lost for any reason, your credentials
@4000000067d57c7909d73fbc file will not be recoverable, you will have to delete it and re-enter
@4000000067d57c7909d74b74 your credentials.
@4000000067d57c7909da8f64
@4000000067d57c7909da934c You should set your own key using the 'credentialSecret' option in
@4000000067d57c7909daa2ec your settings file. Node-RED will then re-encrypt your credentials
@4000000067d57c7909daaea4 file using your chosen key the next time you deploy a change.
@4000000067d57c7909dab674 ---------------------------------------------------------------------
@4000000067d57c7909dac22c
@4000000067d57c7b17896dc4 15 Mar 14:11:13 - [info] Starting flows
@4000000067d57c7d0c664354 15 Mar 14:11:15 - [info] Started flows
@4000000067d57c7d2020a9ac *** starting node-red-venus ***
@4000000067d57c7d253bab6c *** Waiting for localsettings...
@4000000067d57c7d2834696c *** Starting in normal mode
@4000000067d57c833a3ebe64 [info]: loading /data/home/nodered/.node-red/settings-venus.js failed
@4000000067d57c833ac68434 [info]: loading /data/home/nodered/.node-red/settings-user.js failed
@4000000067d57c8513cd7734 15 Mar 14:11:23 - [info]
@4000000067d57c8513cd9674
@4000000067d57c8513cd9a5c Welcome to Node-RED
@4000000067d57c8513cd9e44 ===================
@4000000067d57c8513cda614
@4000000067d57c85144f8fe4 15 Mar 14:11:23 - [info] Node-RED version: v3.1.13
@4000000067d57c8514906974 15 Mar 14:11:23 - [info] Node.js version: v20.12.2
@4000000067d57c8514ad8e64 15 Mar 14:11:23 - [info] Linux 5.10.109-venus-21 arm LE
@4000000067d57c8a25a9615c 15 Mar 14:11:28 - [info] Loading palette nodes
@4000000067d57c9c24c0af0c 15 Mar 14:11:46 - [info] Dashboard version 3.6.5 started at /ui
@4000000067d57ca12d74c994 deviceInstance could not be assigned because res[1][0] is undefined :1.109/[object Object] (com.victronenergy.hub4)
@4000000067d57ca1385dae0c deviceInstance could not be assigned because res[1][0] is undefined :1.56/[object Object] (com.victronenergy.system)
@4000000067d57ca21257ee34 deviceInstance could not be assigned because res[1][0] is undefined :1.106/[object Object] (com.victronenergy.grid.socketcan_can0_vi0_uc436386)
@4000000067d57ca2160df924 deviceInstance could not be assigned because res[1][0] is undefined :1.98/[object Object] (com.victronenergy.battery.socketcan_can0_vi0_uc339800)
@4000000067d57ca2192cf81c deviceInstance could not be assigned because res[1][0] is undefined :1.114/[object Object] (com.victronenergy.packageManager)
@4000000067d57ca21c92cfcc deviceInstance could not be assigned because res[1][0] is undefined :1.102/[object Object] (com.victronenergy.solarcharger.socketcan_can0_vi0_uc430181)
@4000000067d57de50c83d5a4 15 Mar 141715 - [info] Starting flows
@4000000067d57de7063316ec 15 Mar 141717 - [info] Started flows
@4000000067d57de82d5c9a2c starting node-red-venus
@4000000067d57de831f1a30c Waiting for localsettings...
@4000000067d57de833415c5c Starting in normal mode
@4000000067d57def0f185f4c [info] loading datahomenodered.node-redsettings-venus.js failed
@4000000067d57def0f9ffe0c [info] loading datahomenodered.node-redsettings-user.js failed
@4000000067d57df02196afac 15 Mar 141726 - [info]
@4000000067d57df02196ceec
@4000000067d57df02196d2d4 Welcome to Node-RED
@4000000067d57df02196daa4 ===================
@4000000067d57df02196e274
@4000000067d57df021f2c1fc 15 Mar 141726 - [info] Node-RED version v3.1.13
@4000000067d57df02224da34 15 Mar 141726 - [info] Node.js version v20.12.2
@4000000067d57df022404d8c 15 Mar 141726 - [info] Linux 5.10.109-venus-21 arm LE
@4000000067d57df60bb5759c 15 Mar 141732 - [info] Loading palette nodes
@4000000067d57e0803363e24 15 Mar 141750 - [info] Dashboard version 3.6.5 started at ui
@4000000067d57e0c3758b18c deviceInstance could not be assigned because res[1][0] is undefined 1.103[object Object] (com.victronenergy.hub4)
@4000000067d57e0d085e538c deviceInstance could not be assigned because res[1][0] is undefined 1.50[object Object] (com.victronenergy.system)
@4000000067d57e0d1cea560c deviceInstance could not be assigned because res[1][0] is undefined 1.95[object Object] (com.victronenergy.grid.socketcan_can0_vi0_uc436386)
@4000000067d57e0d1e2556ac deviceInstance could not be assigned because res[1][0] is undefined 1.92[object Object] (com.victronenergy.battery.socketcan_can0_vi0_uc339800)
@4000000067d57e0d21a78c14 deviceInstance could not be assigned because res[1][0] is undefined 1.46[object Object] (com.victronenergy.packageManager)
@4000000067d57e0d29e03cdc deviceInstance could not be assigned because res[1][0] is undefined 1.90[object Object] (com.victronenergy.solarcharger.socketcan_can0_vi0_uc430181)
@4000000067d57e0e119a7264 15 Mar 141756 - [info] node-red-contrib-home-assistant-websocket v0.75.0 nodes initialized
@4000000067d57e1000e86624 15 Mar 141758 - [info] Settings file usrlibnode_modulesnode-redvenus-settings.js
@4000000067d57e100152e7c4 15 Mar 141758 - [info] Context store 'default' [module=memory]
@4000000067d57e1001e2f6ac 15 Mar 141758 - [info] User directory datahomenodered.node-red
@4000000067d57e1002095eb4 15 Mar 141758 - [warn] Projects disabled editorTheme.projects.enabled=false
@4000000067d57e100292e5bc 15 Mar 141758 - [info] Flows file datahomenodered.node-redflows.json
@4000000067d57e10141ce724 15 Mar 141758 - [info] Server now running at http127.0.0.11880
@4000000067d57e101684270c 15 Mar 141758 - [warn]
@4000000067d57e1016844264
@4000000067d57e1016844a34 ---------------------------------------------------------------------
@4000000067d57e10168455ec Your flow credentials file is encrypted using a system-generated key.
@4000000067d57e10168461a4
@4000000067d57e101684658c If the system-generated key is lost for any reason, your credentials
@4000000067d57e1016847144 file will not be recoverable, you will have to delete it and re-enter
@4000000067d57e1016847cfc your credentials.
@4000000067d57e101687e02c
@4000000067d57e101687e7fc You should set your own key using the 'credentialSecret' option in
@4000000067d57e101687f3b4 your settings file. Node-RED will then re-encrypt your credentials
@4000000067d57e101687ff6c file using your chosen key the next time you deploy a change.
@4000000067d57e1016880b24 ---------------------------------------------------------------------
@4000000067d57e10168816dc
@4000000067d57e121faac214 15 Mar 141800 - [info] Starting flows
@4000000067d57e1232f5017c starting node-red-venus
@4000000067d57e123b14716c Waiting for localsettings...
@4000000067d57e130277b4cc Starting in normal mode
@4000000067d57e1927a9f41c [info] loading datahomenodered.node-redsettings-venus.js failed
@4000000067d57e192858357c [info] loading datahomenodered.node-redsettings-user.js failed
@4000000067d57e1b07b35234 15 Mar 141809 - [info]
@4000000067d57e1b07b36d8c
@4000000067d57e1b07b3755c Welcome to Node-RED
@4000000067d57e1b07b37d2c ===================
@4000000067d57e1b07b38114
@4000000067d57e1b081bad0c 15 Mar 141809 - [info] Node-RED version v3.1.13
@4000000067d57e1b084ad744 15 Mar 141809 - [info] Node.js version v20.12.2
@4000000067d57e1b08676bac 15 Mar 141809 - [info] Linux 5.10.109-venus-21 arm LE
@4000000067d57e2035bbda0c 15 Mar 141814 - [info] Loading palette nodes
Mem: 612536K used, 417544K free, 13940K shrd, 23964K buff, 218164K cached
CPU: 58% usr 17% sys 0% nic 20% idle 0% io 2% irq 1% sirq
Load average: 5.12 3.63 1.82 3/295 3715
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
996 965 root S 210m 21% 35% /opt/victronenergy/gui-v2/venus-gui-v2
2787 984 nodered S 243m 24% 10% node-red
1032 1016 root S 29876 3% 5% {dbus_systemcalc} /usr/bin/python3 -u /opt/victronenergy/dbus-systemcalc-py/dbus_systemcalc.py
697 693 messageb S 3608 0% 4% dbus-daemon --system --nofork
976 954 root S 44216 4% 3% {vrmlogger.py} /usr/bin/python3 -u /opt/victronenergy/vrmlogger/vrmlogger.py
1005 990 root S 32500 3% 3% {localsettings.p} /usr/bin/python3 -u /opt/victronenergy/localsettings/localsettings.py --path=/data/conf
1758 1755 root S 8028 1% 2% /opt/victronenergy/vecan-dbus/vecan-dbus -c socketcan:can0 --banner --log-before 25 --log-after 25 -vv
1922 1918 root S 55844 5% 2% /usr/bin/flashmq
998 957 root S 26404 3% 1% /opt/victronenergy/venus-platform/venus-platform
1925 1914 root S 22704 2% 1% /opt/victronenergy/dbus-modbustcp/dbus-modbustcp
1038 1010 root S 20772 2% 1% /opt/victronenergy/hub4control/hub4control
1054 1029 root S 22404 2% 1% /opt/victronenergy/dbus-fronius/dbus-fronius
1593 1556 root S 3272 0% 1% /opt/victronenergy/mk2-dbus/mk2-dbus --log-before 25 --log-after 25 --banner -w -s /dev/ttyS4 -i -t mk3 --settings /data/var/lib/mk2-dbus/mkxport-ttyS4.settings
1041 1024 root S 53032 5% 1% {dbus-modbus-cli} /usr/bin/python3 -u /opt/victronenergy/dbus-modbus-client/dbus-modbus-client.py
196 2 root SW 0 0% 1% [gp]
198 2 root SW 0 0% 1% [pp]
iam now running large os beta version , wanted to test if it also crashes, but it does , so …
