In V3.70~54 the option was added to have mre PV inverter compatabilty.
Tested this with APsystems DS3 microinverter with ECU-C control and adding works perfectly.
Only the dynamic power limit is creating issue, by default dynamic power limiting is enabled which seems logic, as ECU-C is also capable of handling it.
Only after adding this the dynamic power limit is set to 0W:
Even if only 1 out of 5 micro-inverters has dynamic power limit enabled all the inverters go back to 10-15 watt power. The limit is never changing.
In my setup have 5 DS3 inverters and SolarEdge SE2000, there the dynamic power limit is set on 2000W.
Can I manually change the power limit setting to a higher value? Trying to set the limit via node-red doesn’t seems to work, it keeps showing a power limit of 0 watt
