Scanning is truly faster , yayyyy…. Love it , as I like fiddling with that update check button ![]()
Awesome!!!
Was hoping it will one day be grouped better.
Thank you.
Would be nice if the MPII shows the serial number too … been a very long time that it has been missing.
Sadly the menu’s are again as before … hope it goes back to the new improved ordering.
Just curious why this is so important for an update that will be applied to all units automatically, in systems where there often isn’t just one multi so a single serial number cannot be displayed?
You can obviously see it via the device list prior to updating.
If there isn’t a good reason not to, I am sure it is on the list.
Not important at all.
It used to show there on my previous MPII 5kva. Since the warranty replacement, it was missing.
It looks like a bug?
FWIW, more systems internationally are single units than parallel units?
Suggestions:
Show single unit systems serial number, it then looks “finished”.
Units in parallel, options:
a) show the master units serial number.
b) or like the with multiple MPPT’s, show each unit and their serial number.
c) or remove all serial numbers for consistency?
