V3.60 - DESS toggle switch disappears
DESS (quick) toggle switch disappears from quick menu after turning it off and reopening the VRM app. The Dynamic ESS view (with energy price and schedule) also disappears. To me it looks like the toggle switch turns off the switch in the DESS settings that say “By turning this on, you will be able to toggle…” I guess this shouldn’t be effected by actually toggling the switch it adds to the quick menu? 3.60~24 I haven’t had this issue before.
3.54 works fine. With ~25 the problem appears again.
Does it behave correctly if you roll back to the previous version?
Moving to Venus beta section.
The same problem appears with 3.60~39.
Can confirm this issue still exists in v3.60~80 @mpvader
Toggling DESS either through VRM or Remote console has the same effect: DESS gets disabled completely in the settings, instead of merely turning Dynamic ESS off temporarily
The following might be related btw.
I am seeing duplicate entries for the “Dynamic ESS mode” property in NodeRed.
Might the toggling bug be a naming clash?
This is still broken in the v3.60 release.
Victron has already notived:
hey all, this was solved in the mean time; or at least something very similar was solved.
I’m marking this one as solved and closed. If there still is an issue then please make a new topic.
