Using two Orion XS connected via VE.direct does not work
In my Setup I have two Orion XS with the latest Firmware (1.08) connected to a Cerbo GX (Version 3.6 23) through VE.Direct. One of them works to charge the leisure battery, the other one is used as a standby charger for the vehicle battery when my camper is parked.
When I connect them both to the Cerbo GX via VE.Direct cable their values and numbers hop from one device to the other on VRM and on the Victron Connect APP as well. Even in the new GUI they switch the values all the time. I would expect the two devices to be shown with their individual values and configurations? Also the VRM Devicelist only lists one of them. Same in the GUI V2 Remote Console
I think this needs to be fixed in the software?
Hmm, das ist sehr interessant – I see this issue elsewhere in this community, with no good answer.
And here, there is an answer “remove them from the network” that seemed to fix a similar problem. Note that I have just posted here, to ask for more details on what it means to “remove them from the network”. I am guessing this means that the two chargers were un-plugged from VE.Direct / Cerbo, and so ONLY visible in Victron Connect app, but I am not 100% certain.
