Multiple DC-DC 50A VE.Direct
Greetings from California USA. I have two DC-DC 50 battery chargers wired in parallel. Using the bluetooth connection, I can see on the Victron App that both are charging as expected. However, only one of the two devices shows up under Devices on the Cerbo GX. Both are connected via VE.Direct cables. Help!?! How can I see both devices under the Cerbo GX Device list? Many thanks! Frank
Maybe one of the cables has a problem?
Try to switch the cables between the devices.
