We are using a 3f multiplus 3000 setup with mppt’s for solar coordinated by a cerbo gx.
We would like to ignore ac when the load is lower then 2000w or when soc is higher then 30%.
And connect to ac when load is higher then 2500W or when soc is lower then 15%.
Therefore we tried the following but it looks like it doesn’t work:
Programmable relay (size: 198):
Use General Flag
Set relay of:
In case of a general system failure
When load higher than 2548 Watt for 10 seconds
When SOC lower than 15% -
Programmable relay (1) (size: 53):
Use General Flag
Set relay on:
When load lower than 2000 Watt for 10 seconds
When SOC higher than 30%
General flag user (size: 5):
Use general flag to ignore AC Input 1
Total size:
Total size of all assistants including the required (hidden) system assistants: 327
Anybody any idea what i am doing wrong?
