GUI V2 - EV charger on ET112 still in AC Loads and missing in VRM
I added a non-Victron EVSE using an ET112 energy meter, but neither VRM or the GX console GUI (V2, OS v3.50) show the power numbers correctly.
The ET112 ‘role’ is set to EV Charger.
All loads are on the Quattro output, running as ESS.
VRM: the EV charger shows up but is always blank ‘-’. The advanced widget shows the EV charger graph correctly and power shows up there. AC load number incorrectly still includes it.
V2 GUI: the EV charger shows up and numbers are correct, but AC load number also incorrectly includes it (either that or pipe lines shown should go between AC loads and EV charger as VRM).
Below example shows pulling 12kW from the grid. 7kW into EV and 5kW additional AC loads. You can see AC loads incorrectly includes the 7kW EV making it appear I have 19kWs of load.
@mpvader is this known behaviour or could my setup be incorrect in some way? Thanks in advance.
I understand future release v3.51 might solve the GUI issue (I’m guessing it won’t/can’t be removed from AC loads).
As to why VRM is blank when the widget works that one is still open it seems.
Update: v3.61 fixed GUI issue
Update Jan 2026 - EV power shown in VRM now from my ET112 (note I have other home battery loads, so 14kW is not the sum of 8 and 7, that is coincidental, AC loads in house is 8-7=1 kW still.)
