Unable to delete old temperature sensors
Hi Victron staff, Hi @guystewart
in the old community forum there were serveral threads about phantom temperature sensors, which were old/inactive and the users are unable to delete them, because they don’t show up in the device list.
Here is a link to such a thread: https://communityarchive.victronenergy.com/questions/130438/vrm-unable-to-delete-device.html
I again would like to ask, if the problem is still on your radar and if you know, when the problem will be solved? It’s there for over more than two years at least.
Thanks for your great work!
Christian
I would like to know also
Usually the cerbo should display “Remove disconnected devices” at the end of the main menu.
(Temperature sensors are not listed in the VRM Device List)
Can you see, if your cerbo / gx displays such an option?
If not, please check what the Temperature-Sensor is showing when selecting it and going to device:
If it says “connected”, then it claims to be connected, just not updating values.
(Therefore, the cerbo does not offer to remove “disconnected” devices)
Hi dognose,
thanks for your post. No, in the Cerbo/GX display there is no such option at the moment. The sensor is ONLY shown in the right widget bar of VRM dashboard:
And by the way, my temperature sensors created with the dbus-mqtt-devices driver for VenusOS are shown in my device list:
So, I think, @guystewart knows the problem, should be on the todo-list, but of course maybe not that important…
But I didn’t want that this topic gets lost due to the new community forum :wink:
Christian
It’s on the radar, it’s a low priority, but by co-incidence I have heard from the team earlier this week they are making a change so at least stale temperature data isn’t shown.
Once that is released I’ll ask again about the ability to remove it entirely.
Thank you very much, I appreciate that the problem is still being addressed. Thanks also for the information. Let’s wait for the changes.
Hi @guystewart, i have also a phantom tremp sensor in my vrm portal and it would be nice to get rid of this. My Installation VRM-Portal ID is: 102c6b643886 and the name of the phantom sensor is: “Fernseher”. He ist not in the device list, but in the Dashboard. Would be great if you can remove this please?
Please let me say thank you for this amazing stuff that victron will provide to there customers. I highly appreceate.
Best regards, Rene
Hi @Rene
I know I have been promising this feature/bug fix for a very long time now, but it is still the same story. The developers have it all scoped and are ready to go, it just needs to be prioritised over other features and fixes, and so far it hasn’t been.
The day will come though.
Hello Christian,
Have you tried to just remove the widget for the offending temperature sensor?
Regards,
Frode.
Hi Frode!
Thanks for the idea, but the problem is, that the sensors show ONLY in the side bar of the site overview page:
So no option to remove anything here.
But maybe one day the issue will come on top of the victron-to-do-list :slight_smile:
Looks like you could ssh into the installation, and edit the settings.xml to remove the old sensors.
Enable ssh trough lan in the remote console, set superuser password.
Open a terminal or putty, type or configure putty:
ssh root@[iptodevice]
Input your superuser password
type yes to accept the ssh key
cd /data/conf
cp settings.xml settings.xml.backup
nano settings.xml
root@einstein:/data/conf# nano settings.xml
Locate the entry for the old sensor (in my example I use my current ruuvi sensor), there are likely two places for the entry, one under the digital inputs:
</digital_input_4>
<ruuvi_f0dc72bcd36b>
      <ClassAndVrmInstance type="s" default="temperature:20" silent="False">temperature:20</ClassAndVrmInstance>
      <CustomName type="s" default="" silent="False">BAGASJE</CustomName>
      <Enabled type="i" min="0" max="1" default="0" silent="False">1</Enabled>
      <TemperatureType type="i" min="0" max="6" default="2" silent="False">2</TemperatureType>
    </ruuvi_f0dc72bcd36b>
And one after system setup:
</SystemSetup>
<TempSensorRelay>
     <Mode type="i" min="0" max="100" default="0" silent="False">0</Mode>
       <Enabled type="i" min="0" max="2" default="0" silent="False">1</Enabled>
       <_0>
         <ClearValue type="i" min="-100" max="100" default="0" silent="False">12</ClearValue>
         <Relay type="i" min="-1" max="100" default="-1" silent="False">-1</Relay>
         <SetValue type="i" min="-100" max="100" default="0" silent="False">7</SetValue>
       </_0>
       <_1>
         <ClearValue type="i" min="-100" max="100" default="0" silent="False">0</ClearValue>
         <SetValue type="i" min="-100" max="100" default="0" silent="False">0</SetValue>
       </_1>
   </TempSensorRelay>
Use ctrl+w for search in nano. do it multiple times to find additional lines. To identify entries for your sensors, you could search for “Luft” for your first one, and “Giebel” for your second. make note of the unique number to search for the second entry for each sensor.
I have not tried this myself, but I would like to think if you delete the content between the start identifier : <ruuvi_f0dc72bcd36b> and end identifier: </ruuvi_f0dc72bcd36b>, save the file and exit(ctrl+o, then ctrl+x), then reboot the system (type “reboot” in the terminal), you will not see the entries for the sensor anymore.
If something is not working anymore, you can restore the old settings.xml by:
cp settings.xml.backup settings.xml
Regards,
Frode.
Hi Frode,
thanks for the hint. I looked into my settings.xml, but the “ghost sensors” are not listed in this file. This is consistend with the fact, that these two “ghost senors” are NOT listed in my device list either on the Venus device itself nor in the VRM portal device list.
I think the two “side widgets” are generated from the data stored at Victrons servers. Last time I downloaded all my data from VRM portal, there were these old last values from the two sensors. That was more than two years ago, that the sensors produced data.
So the problem is, that I cant’t do anything to “delete” this data or say the VRM portal to NOT show sensors with data older than 6 months or so…
I know it’s on the to do list of Victron developers, but I assume with very low priority…
But thanks for your idea!
Christian
Ok, then you could try to add the sensors to the xml file (using the data from the backup of the vrm), and after reboot, try to delete them from the vrm portal.
Last effort, backup your logs and xml file (without ghost sensors), and
Delete install from vrm, re-add it to vrm, check to see if they are gone, if so, great.
If not:
Reinstall the system from scratch, delete install from vrm, maybe save the xml file for easier setup? or setup manually.
Regards,
Frode.
Is there any update to this? I also have a phantom temp sensor that’s been around for 5 months. Thanks!
It’s not forgotten,
The future direction of the dashboard is getting some attention from the VRM team at the moment.
I’ll ask if that precludes crossing this specific long standing feature request off the list.
The debate is how much customisation do we allow there, and the result of that changes how this is implemented.
Just following up to see if there are plans to address this in the semi-near future?
Hi @jsalbre
I think this is working now. I just tested it and it did as I expected;
If you delete the temperature sensor from the device list in VRM it should also be removed from the dashboard;
Amazing! I just tried this for an old tank sensor though I realized the device list doesn’t show it? I tried toggling the Cerbo input on / off just to see if I could get it to show up.
Is there a way to delete the old data for a tank sensor?
My sensors unfortunately don’t show up in “Devices” on VRM.
Hello Guy,
Thanks for the update, but unfortunately, even with the latest VRM version, I was unable to delete my “ghost sensors”; they weren’t even visible in the device list.
However, I have now managed to get rid of my ghost sensors (with VRM IDs 5 & 7):
With the help of dbus-mqtt-devices 0.9.0 ( GitHub - freakent/dbus-mqtt-devices: A driver for Victron VenusOS GX devices to support use of dbus-mqtt/flashmq-mqtt ), which I already had installed, I created several new “temperature sensors,” which were then assigned the next available VRM IDs, in my case 3, 4, 5, 6, and 7. So I created five new devices.
These were steps 1-3 from the section “How to use this driver - The Registration Protocol.”
I then fed these with temperature values so that the sensors appeared in the VRM (after a minute or so, step 4).
After that, I set the new sensors back to inactive with dbus-mqtt-devices (“connected”: 0 → step 5).
Then I went to the device list in the VRM and deleted my newly created temperature sensors with the VRM IDs 3, 4, 5, 6, and 7 one after the other.
This also resolved my old “ghost sensors,” as the same VRM ID was assigned during the process above and deleting them apparently deleted the ghost sensors.
I hope this procedure was understandable and may help some who still cannot delete their ghost sensors.
Good luck!
