TSConfig manual? / Questions for the right Buck-Boost-settings
Hello together,
is there any manual to TS-Config-Software? (not Buck-Boost) - i unfortunately can´t find it at all usual places. I´m unsure about the right values programming a Buck-Boost 100 A in a 24V-system.
The Buck-Boost is used for loading cabin-batteries 24V (Victron Smart Lithium 800Ah 24) from a Mercedes-Unimog Starter-Batterie, also 24V. The complete System is Victron: Lynx Smart BMS and Distributors, Cerbo-GX, Multiplus 24/5000, Smart-Solar, Orions for 24V an 12V-Loads, Battery Protects for all loads and for the Buck-Boost to avoid overloading.
I would like to figure out the correct-settings for No. 27, 31, 90-93 see the screenshot appending.
Thanks for any help an greetings from Düren / Germany
