Can the Buck-Boost-DC-DC-converter also be used with old alternators?
Hi All. Ich möchte auf einem Boot die Bugstrahler Batterien mit dem Alternator der Starterbatterie laden. Da es sich um einen älteren Alternator (nicht Intelligent) handelt, stellt sich mir die Frage, ob ich den Buck_Boost hier auch verwenden kann. Zudem, habe ich irgendwo die Information gesehen, dass man den Lader auch mit dem D+ Signal (Zündung) steuern kann. Ist das so und wie muss ich verkabeln? Für Inputs bin ich sehr dankbar.
Hi All. I would like to charge the bow thruster batteries on a boat with the alternator of the starter battery. Since it is an older alternator (not intelligent), I am asking whether I can also use the Buck_Boost here. In addition, I have seen information somewhere that the charger can also be controlled with the D+ signal. Is this the case and how do I have to wire it? I would be very grateful for any input.
There’s several ways to set them up, I’d suggest downloading the manual off the website and taking a read through it
If you have a decent voltage differential between static voltage and charging voltage (ie 14.5v charging, 13.5v resting, you can use the auto detect feature to turn the unit on/off at ~14v. Alternatively there’s several ways to use a wired source to switch it on/off
Thank you for your answer. Unfortunately, you don’t answer my question directly. So it can be used with a traditional alternator. Yes or Not?
Pin 1 + 2 are, as I understand it, 2 pure relay controls for on/off in series.
What I also noticed is that although you can have a buck-hoost for 100A, it can only utilize 50A in 24V operation. In the specifications for determining the input and output fuses, however, there are also specifications for operation with 100A/24V. What now?
I have also downloaded the software and carried out a simulation. However, I had problems selecting the specific device, because the designations in the software (ts400/800/1600-C2/3 etc,) do not correspond to the Victron device designations.
Yes it can be used with older alternators.
