Is there any documentation regarding the default values for the Buck-Boost DC-DC Converter (12V-12V, 25A)? I’m particularly interested in the output charging voltage. Just want to ensure the default settings are compatible with my LiFePO4 smart batteries.
Otherwise I might need to remove the fuse on the output, start the vehicle, and run TSConfig for it. But I figured the default values are probably documented somewhere.
I’ve looked through the manual on this page and didn’t find anything.
Thanks!
