Temporary MOSFET Temperature Increase on JK BMS Without Load – Normal Behavior or Hidden Issue?
Hello everyone,
I’ve noticed an interesting behavior with jk-bms:
  • The MOSFET temperature briefly rose to around 5°C, even though there was no load connected, and then it dropped back to normal ambient temperature (~5°C).
  • There were no other anomalies: current was zero, and cell voltages were stable.
  • This is happening periodically (week/s)
My questions are:
  • Has anyone else observed this behavior on JK BMS units?
  • Is it possible that the BMS periodically tests the MOSFETs internally, even without load, to check their functionality?
  • Or is this just a normal fluctuation caused by internal electrical noise or sensor measurement quirks?
Any experiences, technical insights, or official information would be highly appreciated!
P.S. graph - at 9PM started to charge my car with 7.2kWh
Thanks in advance!
You may want to add:
BMS Type
BMS Version
Firmware version
Steps to reproduce this
Have a read of this article explaining how back to back MOSFETs work in a BMS when ATC or ATD are active at low current flows and the body diodes are used for the current path. Could this be what is happening in your case.
Both CH and DIS are always on and there’s no alarm on BMS. At that time - not balancing, no current consumption reported by HA or VRM and no variation in cell voltages (dropping). Afterwards everything going back to normal (I have 4 battery packs that I can data compare with). I can monitor each battery individually and there were no sharing currents between banks.
I’m not seeing this on my 2 JK inverter BMSes, the MOS temperature always seems to be related to the current.
Well guys, same hour but different day, mystery finally solved. Yesterday I was just checking remotely. Today I’m standing right next to the battery banks. And guess what… it’s exactly what it looks like…Verry funny.
Thanks for letting us know, we all try to think of esoteric electrical or code causes and miss the external factor.
Haha. I’m still looking at your photo and…seriously. I have no idea. What am I missing?
The sun on JK
Haha. I thought about that, but didn’t expect it to do that much. Nice.
My father used to tell us; if you can’t find it, then it is usually right in front of you.
