System Stuck Issue on Victron Cerbo GX
We’ve encountered an issue with the system where, after prolong use, the data on the Victron Cerbo GX becomes stuck. The only resolution is to have someone restart the system on site, after which it functions normally again. This issue tends to occur every few months.
Could This be a communication protocol problem? Are all the inverters using the same protocols? Also, where can I find the inverter communication protocol?
