my Magnum 2012 inverter died, looking to change over to Victron MultiPlus unit. I would like to see if anyone has Swapped just the inverter. and would it work with the rest of the components in RV auto throw switch so forth, or would I have to change all components over to victron. I just need basic power when I am not running Genset or plugged in to 50amp. Have yet to find a dealer that will answer my question without wanting to charge me money for consultation.
where is the problem i have look the magnum is only an inverter and charger.
but more informations are good did the battery have an useable BMS ? when not best is to build a sytem like this
MP as inverter charger
CerboGX
BMV or smarshunt as Battery Monitor
when you want to display your solar MPPts a second shunt as MPPT emulation
Maybe share a picture of your set up. Blind internet advice is not the best.
Are you going size for size swap (2000Va?). From the last swap i did in a home from magna to victron i had to change all the DC cables and fuses they were undersized for the victron.
It is easy for you to evaluate from the manuals though linked at the bottom of the page here.
