I am developing a small ess system in node red with amongst others an older multiplus compact 24/1200. I want to switch off the muliplus when not needed because it takes relatively much energy in these dark months. I tried the node ve.bus system with enable/disable pv-inverter with mode is adjustable set to 1. However th multiplus is ignorant to the inverter enable/disable command. I work in ESS Mode “external control”.Does somebody have any advise? Thanks in advance. Jan
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus Betriebszustand über NodeRED auslesen | 17 | 763 | 16 August 2024 | |
| How to switch multiplus gx II inverter and bypass modes by local switch? | 1 | 121 | 26 December 2024 | |
| Wie Eigenverbrauch von Multiplus II 48/3000 v558 dreiphasig mit ESS, Ekrano GX v3.67 senken? | 20 | 614 | 7 January 2026 | |
| ESS Mode Documention up to date? | 5 | 155 | 3 May 2025 | |
| Control Charge and Discharge Power of Multiplus | 9 | 295 | 12 January 2026 |
