I have a 12V system in my camper van that includes one Battleborn 100Ah Li battery, a Victron BMV-712 monitor, and a Victron Orion-Tr DC-DC Smart Charger, non-isolated (to charge from the vehicle altenator). I also have a Simplex Power 600W inverter to provide some AC power outlets, in addition to a number of DC power and lighting cricuits. My issue is that when the van is NOT running, and I turn on the system (via a marine battery switch), the voltage as shown on the monitor drops so low that the monitor goes blank in the span of 1 to 2 seconds. There are no sparks, no hot smell, blown fuses, or any sign of a short. If I then start the van, within 15 to 45 sec the monitor relights and the voltage reading returns to over 13V in a few seconds. The monitor shows 100% battery capacity and the history shows a max draw down of 6A.
The inverter and the charger are connected to the same positive buss bar and each has a 60A inline fuse. If I take out either fuse, while leaving the other in and the van not running, the voltage drop does not happen when I close the battery switch. With the van running and both circuits closed (both fuses in place), the voltage drop also does not occur when I close the battery switch. I can then turn off the engine and the inverter will continue to oprate with no problem.
Any thoughts? Thank you
