Hi all,
A (minor) issue in 3.80~14.
The stepped switch does not respond to setting the ‘dimming’ (numeric) state.
It still correctly responds to the on/off button and I’m able to initiate it correctly with a certain number.
Tried recreating new switches, restarting the Cerbo, to no avail. It works perfectly on 3.72.
Hi Dirk-Jan,
The problem is in de GUI, injection in the node itselfworks fine.
Indeed recognised that it only works in the ‘on’ position, but even then on my 3.80~14 system it doesn’t do anything.
Can I somehow give you access to my system? you can try it for yourself on the console
Just for anyone following this thread. After looking at the system, identified this as a gui-v2 bug, added that to the previously mentioned issue. So once that is solved and tagged into a release, it will start working again.
Meanwhile I suggest using the dropdown type instead.
