Virtual Stepped switch labels
Has anyone figured out how to change the default labels on a stepped switch?
The D-bus path in the wiki is invalid.
The node docs in the help section are usually quite complete about the messaging format to change settings.
They usually are, but there is no mention of labels in the node help. The control help does mention labels for drop down switches.
The D-bus wiki gives a path for labels on multi-option switches. I assumed the stepped switch which also uses the Dimming path would have the same option.
