Start & stop genarator based on the configured autostart conditions
I have not used the Generator Autostart since the new Venus 3.60 was introduced. From the new switch panel, on the top left, I can only choose between manual or autostart, which will act based on the configured autostart conditions.
Under Relays, there is no way to set the conditions, so, where are they hidden now?
I would rather not have to go back to the classic view just for this if I can avoid it.
Thanks
From the intro to V3.60 slides ( https://ve4.nl/v360-slides ) the generator settings are found in Settings / Devices / Genset per the image below.
Excellent, thank you very much :folded_hands:
