[SOLVED] Help needed, Lithium NG batteries wont balance
I have 4 x 12v lithium ng 300ah batteries in Parrallel, connected with Lynx power in and Lynx BMS NG. All running latest firmware.
After two months since I last charged it up (and cells were balanced) I connected the boat to Shore Power to recharge, and batteries had 30% remaining.
I have now done three recharge cycles with 8h absorption charge for balancing using the skylla 65Amp charger, and the batteries only reach 88% charge (I could sync this soc value) but the celles continue to say imbalance, even though lowest and highest cell voltages are the same value of 3.55v.
I also note that the skylla will not stay in advanced settings mode.
Whats wrong and how do I solve it?
Thank you.
Alex
Have you confirmed that the batteries got up to 14.0V with a tail current of less than 4% of 1200 = 48A. The Lynx NG BMS only charges at 14.0V so that is what you should set the Skylla to. Where did you set the 8h absorption. If you set that in VictronConnect for the Lynx NG BMS then that has no effect, the Lynx NG BMS only runs absorption until the tail current bis met, the SOC syncs to 100% and the cells are balanced. I do not know the Skylla, do you have that controlled by a GX device via DVCC so the Lynx NG BMS controls it. As above, your first check is the battery voltage and current history.
Thanks so much for the reply.
1: The skylla is not my favourite victron device, and sadly cannot participate in DVCC even though it is connected with VE.Can. Also it still uses a fixed cable from the BMS to the relay on Skylla for Do Not Charge signal. I am actually not aware of any AC/DC Charger (not Multi) that can do DVCC.
2: I have set the 8h absorption on fixed time in victronconnect in the Skylla. I did also set it in victronconnect in the BMS.
3: The charge voltage is set as per screenshot by choosing the smart lithium option in victronvonnect and I cant change that.
4: I have now sync the SoC to 100% and will watch.
5: I will watch the battery voltage, as well and report back.
Many thanks.
As an aside below GX Device screenshots show how the Skylla does not integrate that well, and in fact anything that is not a Multi device does not play well with GX Device monitoring.
Below screenshot of the GX Device, is weird because you cant see that the Skylla is present or charging. The Grid power is coming from a power meter and the AC load is the Skylla.
Yes, I confirm the battery reaches 14v and the status shows the balancer as “Balancing”.
Ok, all a bit strange.
The battery is now balanced. The only change I made was to Sync SoC to 100%, everything else is the same.
Thanks again for the tips.
Note to self for future.
Im still struggling with this charger, mainly now it goes to Absorption too early while all the other chargers in DVCC are still in bulk, so I am going to connect the voltage sense terminals of the Skylla directly to the bus bars at the BMS to help deal with any possible issues with the cable run and connectors from the charger to the bus bars.
Also for general tuning of the Skylla IP65 for participating in a Lithium NG system on a boat, consider increasing the Abs voltage to 15v (from 14.2v) to help stay in Bulk longer until the voltage sense wires are installed, and even then depending on the measured voltage on the sense wires to tune this voltage a little.
As per following post:
I’d avoid setting the absorption voltage to 15 V if you want the battery to last a long time!
True. The lithium NG needs 14.2. This setting is being made in the charger, and due to lack of participation in DVCC and the cabling installation (1.5m 16mm2 and 3m of 95mm2 from the charging busbar) the skylla is going immediately to absorption. So, until I can install the voltage sense wire, I have forced bulk charge by setting 15v absorption. In fact I am only seeing it go to 14.56v while battery voltage is 13.50v There is 70A from the Skylla and another 70A from the solar going in at the moment. I can probably reduce that to 14.5v instead of the 15.
So, I am manually running this to get some charge in to the batteries, and do some balancing. I will reduce the voltage when we get there.
The lack of participation by the Skylla in various Victron systems means that a degree of manual oversight is required sometimes.
Thank you very much for your feedback.
Alex
