I just bought a SolarSense 750. Unfortunately, my Cerbo GX (on the roof) and the device (in the basement) are too far apart for a Bluetooth connection.
I’d like to share 2 personnals projects I wrote (with Claude’s help):
ESPHome SolarSense. You just need an ESP32 with Wi-Fi near the SolarSense, and all the data will be sent to an MQTT broker, for example Home Assistant. I’m using Home Assistant on my side, but it should also work with the MQTT broker running on the Cerbo.
MQTT SolarSense to dbus. You install this one on the Cerbo. The script creates a device on the Cerbo with live data from MQTT, so VRM can see it too.
Thank you for doing this. I told Cursor (AI-enhanced editor) that I had a Victron SolarSense 750 and I wanted to integrate it into Home Assistant. It found your project on GitHub, added the code to an existing bluetooth proxy, I installed the firmware, and badda boom badda bing I have the sensors in Home Assistant. I’m utterly astounded. The bluetooth signal is very weak because the SolarSense is on a metal roof a good distance from the bluetooth proxy, but it’s working.
Victron already natively support a Bluetooth proxy via Shelly, such as their blu gateway. There is no need to do complicated, custom dev work to get it to work.
