While in sustain with Solar & Wind Priority set, the system never recognizes a 100% charge on solar. Which means it always starts charging at the 14 day interval. Not the end of the world but it seems like 100% charge should be 100% charge regardless of what is providing the power.
Maybe you will need to describe your set up more?
Usually if solar doesn’t do the job it is insufficient.
At least on the few i have done it has managed 100% charge on solar.
Sorry if I miss read this but if you refer to 100% your battery, then it depend on the characteristic of battery you own. I see on my system or on friend systems that with same power they charge battery around 1% per 10-15 minutes and as soon as they hit 99% mark, it take hour (5-7x longer) or more to hit 100% - and that is something normal for our battery system made from LiFePO4.
Is your Smartshunt chosen as the system battery monitor and does it reset to 100% by synchronisation, so above the charged voltage AND below the tail current at the same time.
Yes the smart shunt is the battery monitor.
Yes you can reset to 100% by synchronisation.
I don’t understand how the charged voltage AND below the tail current at the same time is taken into consideration with the synchronisation.
See Section 5.7.1 of the manual. A high voltage and low current means the battery is full in other words it has reached absorption voltage AND dropped from Bulk current to minimal current. Also explained in the second link.
Thank you, I read through that and made some changes but we’ll need to watch it for a while now.
