Hello Victron,
Please check solar forecast in DESS for dashboard 442946
It is broken for several days already, however I know that it works for others.
Thanks!
Same here, no solar forecast since a week. I am using a CT sensor connected to Aux1 on my MP-II. Usage is coming in just fine, just the forecast that is broken. Because of that the DESS plan is unusable.
I had the same issue, see my post here: Dynamic ESS PV forecast broken - #20 by Barbara
Victron found a bug and have fixed it. PV forecast is working again for me. Hopefully you’ll find the same.
I know this is an old thread but my solar forecast doesn’t work … kind of. It did work but stopped working a while back
I think there is awareness of the forecast and past data collection. I used to have data in the bar graph … I even used the Next 2 Days previously. I have a solar forecast under Irradiance. I just no longer get a solar/consumption forecast in the bar chart anymore.
Screenshot_20250819-221116863×1152 99.6 KB
I reset Forecasts several times. I’ve moved my location several times … I even relocated to Greece temporarily as I saw on a post.
All of my firmware is up to date
