Victron dynamic ess solar forecast not showing
I’ve just got my Multiplus II GX running with VRM dynamic ESS and everything is working fine, but I don’t see a solar forecast. I have a parallel grid tied Autarco inverter which is delivering to the grid, but when it produces more than I consume I just see the consumption go to zero. Everyday the consumption forecast don’t take in consideration the solar I generate.
Do I need Victron compatible PV inverters to be able to get solar forecasts? Or do I need to configure I have a PV installation somewhere?
same here
@derk Have you told your setup that you have a Grid tied PV system? This discussion may help a bit. Is a PV meter required for an ESS system?
I am using a SMA Grid tied inverter in my system, alongside a MP2.
Have a read of the above discussion and if you still need some help post back again.
In my case the problem was solved when setting the location.
For some reason the location was set to be somewhere in the ocean.
I set it to the correct place and it started working.
