Good morning,
First had it connected to one litime lifepo4 24v 100ah battery, everything worksd fine.
Then I connected two litime lifepo4 24v 100ah batteries in parallel. When I connected them to the mppt it made a strange noise and started smoking!
My system is,
Inverter smart 24/2000.
Mppt smart 100/50.
2x litime lifepo4 24v 100ah batteries.
2x 480w panels.
Fully charged both batteries and connected them in parallel for 24 hour’s before connecting to my charger.
Is the mppt controller abel to handel this?
Or was I unlucky and recieved a defective unit?
Any idea’s please?
Thanks.
There is not a fuse or breaker to be seen anywhere.
Reverse battery connection to the mppt will blow the internal (non replaceable) fuse.
Higher than 100v PV voltages will damage the mppt.
The mppt can be powered via the battery, or pv.
Any bluetooth connection?
Hello there. Welcome in the blue community. Say. Could you please add the brand, type and/or the full specs of your solar panels? Also. At what time did this happen? A nice sunny day?
Ok guy’s,
I think I see the problem! Might have accidently by past a fuse. Talk about beginner’s luck.
Don’t laugh too hard, feel a bit silly now.
Will let you know if I have solved it.
Thanks for the input.
Ehm. You bypassed a fuse, and that caused the smoke?
When I reconnected I ran the red charger lead direct to the battery instead of via the 40a fuse. Which I think if the mppt is rated for 24v 200ah it should not go up in smoke.
I have 2x ja solar 445wp panels. And yes it was very sunny when I reconnected.
Verzonden vanaf Outlook voor Android
Still puzzled about where the smoke was coming from. Was it smoke or a spark?
