Smart Shunt change of location
Hi
due to space constriction id like to move the shunt from its typical location of after the negative bus to just after the inverter/charger. See photo, although this photo does not have a house battery bank like I do. Thank you for your help.
If you relocate the shunt it will not give you accurate SOC because it is not measuring all DC chargers or loads. Below is the only acceptable way of installing a shunt.
