Smart shunt 500 and lifepo4 battery settings
Hello, what should be the correct settings for the smart shunt and my Ultimatron lifepo4 180Ah battery? The system is in the caravan.
Thank you,
Michal SVK
Charged voltage 0.1-0.2V below your absorption voltage, so if you charhe at 14.2V set the SmartShunt to 14.0 or 14.1V
Discharge floor 10-20% depending how low you would like to run.
peukert exponent 1.05
Charge efficiency factor 99%
Leave the others as is
