Battery level not displayed correct
I have a MultiPlus-II 48/5000/70-50, 230V with Victron Energy SHU050150050 - SmartShunt 500A/50mV Connected to my 48 battery bank (2x24v 100ah). The battery level isn’t correct, it jumps up and down without reason. I suspect the battery settings. What are the recomended setting for this battery ?
No help from battery manufacturer.
For the Smartshunt
Key ones are in no particular order
  1. Charged voltage 0.4V below absorption voltage. If you are using 56.8V for absorption then 56.4V.
  2. Tail current 4%
  3. Battery capacity 100Ah
  4. Peukert coefficient 1.05
  5. Charged efficiency factor 99%
  6. Discharge floor 10% or 20% depending on how low you plan on taking them. This is only used to calculate the time to go.
  7. There is a setting towards the bottom of the page about what the unit starts at, if you have a choice then set it to retains value, I can not remember the exact wording.
Leave the others as default.
