Smart IP65 Charger 10A/12v not charging, switching between bulk and abs, after firmware update
Hi @guystewart
as per this post
Smart IP65 Charger 15A/12V not charging, switching between bulk and abs, after firmware update - #20 by necik
Im having the same issue with the 10A 12v smart-ip65 charger after the firmware update, was working fine and 5m later i did the firmware update and bang no longer working
Ive spoken to the place i purchased it from who want me to pay for return shipping to them so they can test it and possible start an RMA
Im not very keen on paying for postage to return a defective item considering im not at fault for the issue
I tried contacting my local dealer but they were less than interested on the phone, but i was advised buy place of purchase it can be returned to any Victron dealer for a replacement
Also finding it hard for the firmware not to cause the issue, within 10m of me using it then doing the update and reconnecting to the battery the unit had failed
Tom
Hi @Tomo951,
You’ll need to get the unit to the place of purchase or a Victron dealer for them to do warranty.
It should be accepted for RMA on the spot if it is exhibiting the same symptoms as described in that other thread.
Alternating bulk and absorption lights and 1A charging limit.
If there is some other symptom or fault it is not the same issue and they will need to do a bench test from the pre-RMA checklist to diagnose.
Hi @guystewart
Thanks for the quick reply
unfortunately the place of purchase is in a different state to me now
The charger has the exact symptoms as the post linked
i do have local Victron dealers but the one i spoke to had never heard of the issue & wasn’t interested in helping me as i did not purchase from them, but i was advised buy place of purchase i can return for a warranty to any of the Victron dealer network, i also cant wait weeks for shipping as i need the charger
WA SOLAR SUPPLIES was the local dealer i spoke to
They might take a bit of encouragement, but it should be possible to use the local dealer.
Next step I would recommend is filling in this form with all that info, including the name and contact details of the local dealer - Need support? - Victron Energy
Eventually that can be escalated to the regional sales manager if necessary and they can have a chat with the local dealer about how giving good quality of service for Victron helps everyone including them in the long run.
Apologies for the issues.
@Tomo951
having the same issue with the charger bought 2022, which works fine so far. After firmewareupdate at 21.April 2025 my product shows same behavier as descript in several posts.
Victron energy statet in their posts this is a HW issue and is not linked with the firmeware update. Startet a warrenty request, will see how fast they will react here in Germany. Might be more causes upcoming soon…
I had a 15A IP65 charger that was less than a year old and lightly used. It did the same. Fault appeared to coincide with a firmware update.
I logged a fault via the Victron website Support pages and was referred to my local dealer but the query was monitored by Victron customer support. I had to pay for shipping the unit back. It was quickly tested, found faulty and replaced. I had to pay shipping for the new unit too but small price to pay for assurance that the RMA process works.
If your local dealer is unenthusiastic, log the fault via Victron’s website support pages.
Was this a faulty batch of relays that has been identified?
I’m looking to buy a charger, but if the faulty hardware hasn’t been rectified I might consider a different model.
Was it across the entire IP65 size range?
I had the same concern. It would be more comforting to see a release from Victron admitting there was a production or sourcing issue, so we don’t end up RMA’ing and ending up with the same issue.
My 15A ‘smart’ charger also shows this symptom this morning when I needed it most. Over the last 3 or so years of owning it - it has been nothing but trouble - constant buggy behaviour.
I spent a lot of money on what I thought was a premium product but in the end I have lost my faith. Even the material the power lead is made of has crumbled away near the entry to the charger to expose the AC wires despite light / indoor use only. It goes in the bin this morning.
Hi @guystewart
I have the same issue with my device. I claimed it at Victron support with the failure description “Alternating bulk and absorption lights and 1A charging limit.” and they gave it to Transwatt here in germany. Because my dealer is no longer existing (Bosswerke), Tanswatt wants to have money (40€) for the handling. As this should be a well know issue, why cant Victron just send me a new device?
Who can help?
Hi @laun
Sorry for only seeing this message now,
When the normal supply chain to you (your dealer) is no longer available, and other dealers are not being co-operative then you can contact your regional sales manager and ask them for assistance.
The contact list is at the bottom of this page;
Hi @guystewart ,
thx, did it.
Looking forward for a good solution.
UPDATE : The replacement unit has now also failed after about a year of occasional use. Similar symptoms. I suspect there is an issue with these units.
I downloaded and ran the RMA test procedure out of curiosity (I have suitable test equipment) and it failed the part where it does not supply the full rated charge current and does not respond to increases in the DC load on the battery being charged.
I will be returning this unit for a warranty claim but I am also going to buy a different charger as I have lost trust in the 12V 15A IP65 design after two failures. I use this unit to occasionally charge a 12V 100Ah house battery that runs a fridge in my 4x4. The location is well ventilated and the duty not arduous. All my other Victron equipment functions flawlessly.
I contacted the german sales manager 4 weeks ago but there is no answer till now. Not what I expected :wink:
thx
I also have the smart IP65 charger 12 volts 15 amps and it failed as well today. It worked fine 6 months ago but today I try to use it and it gave me an option to update from her to 3.65. Now the charger stays in test mode for a few minutes then jumps to bulk then absorption Within 30 seconds. The current stays under 1 amp.
Video
Hi, I need to buy a battery charger for my car and wanted to buy the 12V/15A. I need to charge the car battery regularly. I currently charge it once every 2-4 weeks as I don’t do enough driving. I’m currently using a cheap charger that is on it’s way out, but reading about this issue is making me have second thoughts about buying. I am 99% on wanting to buy Victron if not for this issue I’m reading about.
To Victron, has this issue been fixed in newer models? I can’t afford to do the RMA all the time as I need a reliable charger to charge my car battery very regularly to get to work (I only really drive to work and nearby store/s, can’t afford to drive around to keep the battery charged due to cost of fuel). If I lose my job because I can’t charge my battery, I will be in big trouble. Please tell us if this issue if fixed in newer models. And if it hasn’t been fixed and I do buy this model, send for RMA, then get another one and it also does the same thing, can you request refund of your money? I can’t afford to eat the cost of the charger to buy a different model/brand, so can money be refunded if subsequent models also do this? Please respond.
The main reason I want to buy Victron is because of the connector eyelets (this would make it a lot easier) as I plan to charge my battery once every 1-2 weeks instead of the 2-4 weeks I am currently doing. Current charger doesn’t have that option and is on it’s way out.
Edit : Also, when you first get the charger, and if it’s working fine, do you have to update the firmware? Is that optional to update the firmware?
