Does FW update V3.65 fix charging problem (alternating bulk/abs) with charger Blue Smart IP65 12/15?
Hi all and especially @guystewart and @mpvader !
My Blue Smart IP65 12/15 charger (bought Nov 2024) stopped working during our trip with our RV through Europe this summer. It has the exact same problem (“Alternating bulk and absorption lights and 1A charging limit”) as others have mentioned on this forum before, mostly from October 2024 until the first part of 2025:
https://community.victronenergy.com/t/blue-smart-charger-ip65-12-15-low-voltage-and-current-firmware-bug/5863
https://community.victronenergy.com/t/problem-with-ip65-12-10/14448
https://community.victronenergy.com/t/smart-ip65-charger-15a-12v-not-charging-switching-between-bulk-and-abs-after-firmware-update/13672
https://community.victronenergy.com/t/smart-ip65-charger-10a-12v-not-charging-switching-between-bulk-and-abs-after-firmware-update/20197
Everyone in the above threads were blaming firmware update V3.61 to be the cause of this charging problem but after an investigation by Victron this was then resolutely denied by both Matthijs Vader and Guy Stewart (both working for Victron) here:
https://community.victronenergy.com/t/smart-ip65-charger-15a-12v-not-charging-switching-between-bulk-and-abs-after-firmware-update/13672/9
https://community.victronenergy.com/t/smart-ip65-charger-15a-12v-not-charging-switching-between-bulk-and-abs-after-firmware-update/13672/21
They stated an underlying hardware defect in certain charger units was already causing this behaviour/problem and updating to V3.61 just made it more visible because the LEDs also would show this behaviour now.
Quoting Guy Stewart:
“A charger that is showing this characteristic still had this fault in its hardware before the firmware update, and downgrading the firmware will not remove the hardware fault.”
Last week I contacted the (web)shop where I bought the charger to start a RMA procedure. I informed them about the underlying hardware defect and gave them the links to the above threads on this forum. Still they wanted me to update to V3.65 first and test the charger again before I was ‘allowed’ to send the charger to them for testing/RMA.
So, this weekend I updated my charger and imagine how shocked I was to find out it was working again!
I tested the charger last weekend several times by disconnecting the mains, turning all the lights on (12V) for some hours drawing about 5Ah, then connecting the mains again so the charger could ‘do it’s thing’ and that all seems to work again.
But I have troubles ‘accepting’ this problem as solved now because of the above statements made by Matthijs and Guy from Victron claiming it was/is a hardware fault.
So, over to my actual questions to @guystewart and @mpvader :
  • Has the update to V3.65 really fixed my charger or is this just a coincidence?
  • If it fixed it, how is this possible regarding to the hardware fault you claimed earlier to be the cause?
  • And can you guarantee me that your software fix is not some kind of ‘bush fix’ just temporarily working around the real hardware problem? Leading to a possible malfunction of the hardware in a couple of years (outside the 5years guarantee period)?
  • If it didn’t actually fix it, how can I get my charger replaced now it doesn’t show the ‘symptoms’ anymore?
  • And if it has to be replaced, how do I know this exact problem isn’t going to occur again with the new charger? I guess you replaced the hardware part with a newer version? Can I check the serial number or something like that?
As you might understand from the above questions, I lost my faith in Victron or at least in this particular Victron charger and hope you are willing and able to restore it.
To all others having or having had the same problem with their Blue Smart IP65 chargers, please write in this thread how you solved it (FW update or replacement).
Hi @Magnus ,
to know if the charger is good or not, use it to charge an empty enough battery:
while charging, make sure the charge current goes above 1 amp. When above 1A, all is good. When it charges with 1A only, then there is a defect in the charger.
To me, it sounds like just a coincidence.
There has been no working around, and actually no related changes at all in v3.65.
Ps. that the webshop wants you to update is standard, and not specific for the charger. For any RMA and any possible defect, updating to the latest version is part of the mandatory steps.
Hello @mpvader and thank you for taking the time to answer my question!
During my first tests directly after upgrading the firmware to 3.65 it seemed like the charger was working again, charging my battery with up to 15A.
But I thought the charging process seemed a bit odd because it went very quickly from Test → Bulk → Abs (12.51V / 2.1A) and then back(?!) to Bulk (14.9A) for 10 minutes as the voltage increased from 13.94V to 14.71V, after which it again continued to Abs (when the voltage became ~14.7V) and charged first with 14A and then the current decreased for a few hours until it switched to Float (13.8V / 7.8A).
Triggered by you mentioning “use it to charge an empty enough battery” and the fact that the battery was almost full when doing my earlier tests directly after the firmware update I decided to run a ‘final’ test last week with a half-discharged battery (according to the camper’s system: ~53% and 12.3V) instead of an almost full battery (~92% and 12.5V).
And now the charger failed again!
This time it was first in the Test stage for a minute or so (never taken that long before) and then in Bulk for a few seconds and then directly to Abs. The voltage in both the Test and Abs stages according to the Victron app was 12.32V and the ‘charging current’ 1.0A. In contrast to last Sunday, the charger did not go back to the Bulk stage after a minute or so and since the lights were still on, this meant that the battery continued to be drained even though it was being ‘charged’…
After 7 minutes in Abs and ‘charging current’ 1.0A I thought it was enough and turned off the lights in the camper so no current was consumed (before the consumption was about 6-7A) to test if it might affect the charger in any way. Disconnected the charger from 220V, waited until the charger’s LED lights went out, waited another minute and reconnected the charger to 220V.
And then the exact same thing happened again: Quickly to the Abs stage (now 12.49V / 0.9A) where it remained for 3 minutes before I disconnected the charger and connected the CTEC 5A charger (which I had to buy abroad this summer) instead. It has exactly the same stages as the Victron charger and it did exactly what it was supposed to do: max current in the Bulk stage until the Abs voltage was reached and then to Abs etc.
So, I guess my charger isn’t OK after all and needs to be replaced?
Is this (failing) different behaviour while charging a half empy battery compared with an almost full battery something you can confirm in relation to the failing hardware?
After the update to 3.65 I don’t get the alternating behaviour between Bulk and Abs anymore, it just stays in Abs the whole time. Is this something you recognize?
And why did the app state the battery voltage was 14.7V during my first tests? I am running the charger in Normal mode, not in ‘High’ mode.
Question for @symovo : In this thread https://community.victronenergy.com/t/blue-smart-charger-ip65-12-15-low-voltage-and-current-firmware-bug/5863/10 you wrote your problem was fixed with update 3.65. Can you please confirm that still is the case? And if so, did you try charging a half empty battery too or are you just ‘maintenance’-charging a battery?
Hi again @Magnus,
Long story short: yes, that charger needs to be replaced.
Sorry for all the trouble!
Matthijs.
Hi @mpvader !
Ok, I understand and will continue with the RMA then.
But there are 3 things that worry me:
  1. If the webshop test the charger in the ‘wrong way’ they might think it works as expected, send it back to me and I have to pay about 70 euros for their investigation and still have a faulty charger. I will give them exactly the same test information as I did here but I wonder if they could contact you in case of doubt?
  2. If they agree to send me a replacement charger, how do I know this exact problem isn’t going to occur again with the new charger? Can I ask them to check the serial number or something like that to be sure I get an updated version of the charger?
  3. In case there isn’t an updated version of this charger, how about the 5 years warranty? Will that ‘reset’ for the new charger?
Hi @Magnus , I’m quite sure your supplier will OK to replacement, and if not they can double check with our service department.
Its really not very common for a charger to have that fault; even though it has been one of the more occurring faults - and therefore shows up now and then in online reports.
NO V3.65 does not fix anything. The last time I used my ip65 12/15 was 6 months ago. It worked perfectly fine. Then a few days ago I updated to fw version 3.65 and the charger now exhibiting the fault. I read that it’s not the firmware that caused this but some Hardware problem. What I don’t understand is why was I able to charge my battery 6 months ago on the old firmware without any issues? Is there a way to roll back below 3.61 just to verify?
The charger stays in test mode for a few minutes then jumps to bulk then absorption Within 30 seconds. The current stays under 1 amp. The power supply mode acts the same. It’s like the charger lost the high current mode. And now it shows Off sometimes but it’s still charging at low current as I can verify with a SmartShunt and a clamp meter. I tested it on three different batteries. Some say the relay went bad, how could it go bad just by sitting for 6 months?
Here’s a video of how much charge your face now. It’s pretty much useless boat anchor.
Hi @flywheelz,
As with others in this thread, if the charger is running the latest firmware version and still will not charge above 1A then you will need to get in touch with your Victron dealer for an RMA warranty replacement.
I purchased the charger on Amazon and the seller/dealer is no longer selling any Victron products. As a matter of fact this particular charger ip65 12v15a has been pulled from Amazon. Maybe it was pulled from the market in USA due to this Hardware failures? By using support email, I was contacted by a different dealer 3000 miles away, I will need to pay shipping there and back and hopefully they will waive the Diagnostic fee. I was playing with the charger today switching modes, switching voltage, and somehow it started charging at 15 amps but only for about 20 minutes then it dropped to 1amp. During the Absorption stage.
Enter your product serial number into this support page and it should connect you with a distributor who can help;
The dealer likely went out of business. So I created a request for support and that’s how I got contacted by another dealer across the country.
Blue Smart IP65 Charger
Serial no#:HQ2216UPCGF
Warranty: years
Part no#:BPC121531104R
Dealer:Original dealer not found
Support
We’re sorry, the original dealer cannot be identified.
There could be various reasons for this, for instance the original dealer has discontinued the business. The quickest route to get support will be to create a support ticket.
Your request will be sent to the Victron Energy sales team. They will match your request to another suitable local dealer who will support you.
I have good news to report. After contacting Victron I was connected with a dealer that was very helpful and had me mail him the charger. The next day he said it was approved for RMA and after paying him the return shipping he sent me a brand new charger in the box. It came with firmware version 3.25 and updated it to version 3.65. I did my first charge on the half depleted car battery and it was able to charge 30 amp hours into it. During the bulk stage it was charging at 15 amps. I still don’t like the relay clicking on and off when it switches to the float stage. This cannot be good for the relay. I would suggest Victron to change the firmware so the relay stays on for longer until the current drops to 0.1 amps then turn the relay off which I am guessing turns the high current circuitry off. It’s beeing turned off too early right now and the low current circuitry is not able to keep up and it’s forced to switch the relay back on. I understand some release have long live but there’s really no need to have it click on and off like this.
Hi @flyweelz,
where are you from?
In germany I get absolutely no help… Even after contacting the salesman here…
have a nice time
My original similar unit failed in the same way. It was returned to the original on-line dealer and replaced under warranty (at cost of shipping both ways). The replacement unit failed the same way almost exactly a year later . It already had the latest firmware.
I downloaded and ran the RMA test procedure out of curiosity since I have the necessary test equipment. During a second test sequence the charger suddenly started working normally at full capacity again. Sadly this “revival” did not last even one full charge cycle on my Li-ion house battery. So I will be returning the replacement too.
I feel sorry for the Victron reps here who have to try and put a friendly face on something that we all know should have been a world-wide recall. All my other Victron equipment works flawlessly.
Hi laun,
I am in USA. I started by going to Need support? - Victron Energy and entering serial. Then requested support. Next day came email from Victron with dealer information.
That’s terrible news that the replacement failed. I wonder if this model has design flaw. This charger is no longer sold on Amazon. Do you know of any other model that’s reliable?
I suspect a batch of substandard components may have affected one or more production runs.
I now got an embarassing formal letter from the DACH sales manager Christoph Briel and to be honest: this was my first and my last devide, I bought from Victron.
I assumed that would be a reliable chineese vendor but…. what a mistake.
CU
