Smart Battery Protect Remote On/Off Delay
I am using a Smart Battery Protect 12/24|100 and I have the following issue.
As described in 3.3.1 of 3. Installation and wiring examples the load should be disconnected after 90s when removing the wiring on the remote connector (H-L). When checking in 4.4 of 4. Operation and programming it then says that the load is actually disconnected immediatly.
Are those two different modes? If yes, how can I change them. Currently the load is disconnected immediatly and I actually need first the alarm to be triggered before switching of the load. Is this possible without additional hardware?
Thanks for the help, Nino
Is there anyone who could help resolving this issue?
It will be disconnected immediately in the case of a short circuit. Manual 4.4.4.
Otheriwse the delay is 90s.
Thanks for the help!
But my load also gets disconnected immediately when opening the remote switch. I tried with both of the wiring examples from 3.3. Are there some specific settings required?
As far as I know no.
