I am using a Victron Smart Battery Protect in my system and would like to know if the H and L terminals can BOTH be used to form a dual method of disabling the unit, the manual says"
" 1. A remote on/off switch can be connected between Remote H and Remote L. Alternatively, terminal H can be switched high (to battery positive), or terminal L can be switched low (to battery negative)."
BUT does not mention if I can use both or the terminals and if either one matches the required voltage the unit will be disabled.
Thanks in advance.
Cheers
Mal
