Skylla-TG for lifepo4 charging
I’m having trouble setting my Skylla-TG 24/30 to charge my 24v lifepo4 batteries correctly.
Whatever I do it seems to go for boost charging and then break off, and then continously restart boostmode once the battery voltage drops. I can’t get it to slowly drop the amp once it hits the chargevoltage…
I’ve tried multiple setting with DIP settings and voltage but I can’t seem to make it work correctly and my batteries need frequent balancing with a different charger. Have anyone had luck with setting it up?
I’ve tried the following
Boost ON/OFF
EQ 0/4/8/12
Boost 29.2 / 28.8
Float 28.8 / 28.8 / 27.2
Kind regards
Anders
