We have a Lynx Shunt VE.can with its battery temperature sensor installed and measuring the battery temperature correctly.
The Lynx Shunt VE.can is connected to a Cerbo GX and Skylla IP65 by a VE.can network.
Can the Skylla IP65 charger use the battery temperature via the VE.can canbus (being measured by the Lynx Shunt temperature sensor)?
Thank you in advance
Richard
