Skylla-IP65 12/70 (3) charge data
I have a Skylla-IP65 on my boat.
Is there a way to get get the data from this charger visible in an app?
The charger has been mounted under the bed so the display is normally not visible.
These old chargers have no data interface. The only way to get charging information would be to ad a smart shunt into the -ve lead to the battery - you should have some form of battery monitoring installed in any case. Once the shunt is installed, you need to treat the battery negative bus as an active connection - i.e. no wire other than that to the shunt connected to it. You can then get your battery data - charge and discharge- from the shunt.
Thanks Mike.
I do have a smart shunt for the house battery bank.
Was hoping the VE.Can of the Skylla could somehow output all the data.
If that’s not the case I will go for another 2 smart shunts to show the charge current (and battery voltage) of the starter and bow thruster batteries.
Connected the Skylla to the Cerbo GX with a VE.Can cable.
The Skylla showed up in the Remote Console and I could even update its firmware :+1:
