Hi team,
I’m running into an issue with Shelly Plus 1 (Gen 2) devices on Venus OS 3.70~58 on an Ekrano GX, and I have packet-level evidence that the GX is not receiving any CoAP announcements from these devices.
Environment
Victron Ekrano GX
Venus OS v3.70~58 (beta)
Firmware: 1.7.1
Network setup:
All devices on same flat LAN, no VLANs
Peplink MAX BR1 Pro 5G as router (no IGMP snooping options, all traffic untagged)
GX is wired Ethernet
Shellys are on 2.4 GHz WiFi
Connectivity between GX ↔ Shelly (ping, HTTP UI, etc.) is fully working
Problem
Gen 2 Shellys never appear under Settings → I/O → Shelly Integration.
Gen 1 devices (e.g., RGBW2) appear normally.
Gen 2 devices are reachable (HTTP, ping).
After hours of testing, not a single CoAP or mDNS packet from the Gen 2 units reaches the GX.
Packet Capture Evidence
I installed tcpdump on the Ekrano GX and ran:
tcpdump -ni eth0 udp port 5683 or udp port 5353
Here is what I see:
Shelly Gen 1 RGBW2
Multicast traffic appears every ~10–20 seconds:
192.168.50.22.5683 > 224.0.1.187.5683
192.168.50.22.5353 > 224.0.0.251.5353
No CoAP or mDNS packets observed at all:
tcpdump -ni eth0 host 192.168.50.31 and udp port 5683
0 packets captured
However, these Gen 2 devices answer pings consistently:
64 bytes from 192.168.50.31: ttl=255 time=5 ms
So IP-level connectivity is intact; the UDP multicast announcements seem completely absent.
Interpretation
Based on Victron’s documentation, Shelly discovery on GX relies on:
CoAP multicast →
224.0.1.187:5683 -
mDNS →
224.0.0.251:5353
It appears that the Shelly Plus 1 Gen 2 firmware (1.7.1) may not be sending the expected multicast traffic needed for GX discovery, or the GX is not listening for the new Gen2 protocol.
Given:
Gen 1 devices work immediately
Gen 2 devices send no multicast (confirmed via capture)
Flat LAN, no snooping, no filtering
TCP/IP connectivity is normal
Behavior is identical across multiple units
This looks like a Venus OS Shelly integration gap for Gen 2 devices or a Shelly Gen2 firmware issue relating to CoAP announcements.
Questions for the Victron team
Does Venus OS 3.70 Shelly integration support Shelly Gen 2 (Plus) devices yet?
Does the integration expect CoAP v1, and the Gen 2 devices use a different announcement protocol?
Should Gen 2 devices appear automatically, or is extra configuration required?
Is there a known compatibility issue with Shelly firmware 1.7.1?
Happy to run more captures or provide full pcap files if it helps.
Thanks,
Joe
