Shelly integration with MQTT in Cerbo GX with Node Red
could you please help? I can’t get the MQTT to work. The error message is “connection is beeing established”.
Nodde MQTT out:
IP address:
No password:
Configuration of the Cerbo GX:
I was not able to start mosquitto on the Cerbo GX because the port 1883 was already in use. I think there is already a MQTT running?
root@einstein:~# /usr/sbin/mosquitto -v
1770283117: mosquitto version 2.0.20 starting
1770283117: Using default config.
1770283117: Starting in local only mode. Connections will only be possible from clients running on this machine.
1770283117: Create a configuration file which defines a listener to allow remote access.
1770283117: For more details see Authentication methods | Eclipse Mosquitto
1770283117: Opening ipv4 listen socket on port 1883.
1770283117: Error: Address already in use
1770283117: Opening ipv6 listen socket on port 1883.
Es verbindet sich jetzt. Ich habe statt der IP Adresse “localhost” eingegeben. Das macht Sinn, weil der Node Red ja auf dem Cerbo GX läuft und deshalb keine IP-Adresse braucht.
