Cerbo GX unable to connect via MQTT
Hi I’ve be trying to connect a raspberry pi running Node-Red to collect data from a Cerbo GX Firmware 3.75.
I get an immediate (tcp) failed: Connection refused.
When using nc.
From the Cerbo GX I get no Listen on port 1883.
netstat -tln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 127.0.0.1:5900 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
tcp 0 0 172.24.24.1:53 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:1881 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:60989 0.0.0.0:* LISTEN
tcp 0 0 192.168.10.10:60335 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:81 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 172.24.24.1:54079 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 ::1:53 :::* LISTEN
tcp 0 0 :::443 :::* LISTEN
tcp 0 0 :::502 :::* LISTEN
tcp 0 0 :::8000 :::* LISTEN
tcp 0 0 :::22 :::* LISTEN
tcp 0 0 :::80 :::* LISTEN
I have been trying all sorts of things, but with no success.
How do I send a keep alive to port 1883 if its not listening.
I have set Local Network Security Profile to Unsecured with Superuser
Thanks for any help
Mark
Question may sound dumb, but did you enable the MQTT Access in the Integration settings at all?
Under services the MQTT is enabled.
I downgraded the firmware 3.73 and it started showing messages on mqtt explorer. WTF.
Correct. Firmware v3.74 and v3.75 had network bugs introduced. Rolling back to v3.73 was a smart move.
