Hello, I have searched threads and saw dialogue around firmware version 3.55 having higher security and therefore connecting MQTT Explorer required additional settings. I have not found the definitive path to access the data. hoping someone can help. I am trying to connect using 1883 port. I have changed the cerbo settings to unsecured, enabled MQTT and Modbus TCP. Can someone please advise what else is needed as I am only getting the serial number. I’m a beginner with this stuff. Thanks.
You need to first send a keep alive as per the docs. Various other topics on this subject with pointers to get you going.
I use unsecured setting.It works without username and password out of the box on my Multiplus II GX (V3.55)
If you use Weak the username can any and the password is the SSH password.
You see only the serial number, has you change something in the Advance tab?
This is default
Example ad your IP from your cerbo (no username and password)
After 1 minute
Thank you for these screens. I am also using unsecured. i notice you have valid certificate enabled. I do not. I’ll change that. Also, I read in another thread that you have to change the remote console to switch to the new GUI and it will start displaying the data. I haven’t tried that but will.
