Hi all,
I’m upgrading my Hunter 340 sailboat from AGM to LiFePO4 and would greatly appreciate a review of my wiring diagram and build document by anyone with marine electrical experience. I’ve had a marine electrician (Colin Davis) consult on the plan and I want to make sure nothing has been missed before I begin installation.
System overview:
Two LiFePO4 batteries (house bank) with integrated BMS
Existing AGM starter battery (kept separate)
Phoenix IP43 shore/generator charger — reconfigured to LiFePO4 profile, house bank only
Blue Smart IP65 25A — dedicated AGM charger for starter battery (shore/Honda simultaneously with IP43)
Orion XS 12|12–50A (non-isolated DC-DC) — alternator isolation, output set to 30–35A via VictronConnect
Orion-Tr Smart 12|12–18A (isolated DC-DC) — starter battery keep-charge
MPPT 100/50 + two MPPT 100/20 — three solar arrays
BMV-712 (already installed) — shunt on house bank, Aux sense wire to starter battery positive
BEP 770 battery disconnect
Class T fuses within 7" of battery terminals (ABYC E-11)
Galvanic isolator on shore power safety ground
Honda EU2200 as shore power substitute (not simultaneous with shore)
What I’m asking you to look for:
Any wiring errors, missing connections, or unsafe routing
ABYC E-11 compliance issues (fusing, grounding, wire gauges)
Any component interactions I may have overlooked (especially the dual-charger setup)
Anything that looks wrong or that you’d do differently
Design Plan Simplified.docx (248.7 KB)
I’ve attached the wiring diagram (PNG) and the full build WORD document (i Have an HTML — happy to send it - can’t upload on this forum).
Thank you in advance — I’m a 72-year-old occasional sailor and I want to get this right before touching a wire
