Ruuvi tags disappearing on VRM online
When using the Beta iPhone VRM app, Ruuvi tag values will show up correctly for a split second, but then disappear a few seconds later as the display switches to “realtime.” All temperature values, humidity etc get replaced with dashes. See the before/after screenshots attached (“Outside” and “Inside” towards the bottom).
It worked fine on the non-beta version, and it still works fine on iPad and web versions. All is well on the CerboGX display too.
I’m seeing the same behavior, for what it’s worth.
Update: This bug is now appearing on the non-beta web-based UI as well. Must have started yesterday or today.
FYI @mpvader
Hi @silvercreek
The team is aware, apologies for the inconvenience.
We are still evaluating this behaviour of showing a dash instead of old data, but it should not have gone live to the public site before that internal evaluation process was complete.
Hi @silvercreek ,
This should be fixed now and I see all temperatures again for your installation. Apologies to the inconvenience this caused last week.
Have a nice day!
Thank you! Confirmed that the web portal is working again.
The issue remains on the iOS Beta app.
Hi Guy
Is the dash instead of old data a new feature?
The old data on the dashboard was useful as it gave a snapshot of the system prior to last connection.
Regards
Glen
