Reset Overall History (Cerbo, MultiRS Solar) V3.60~25
In the settings on the Remote Console for my Multi RS Solar, you can see Overall History… Is there a way to reset it?
I would like to reset it so I can keep an eye on min/max voltages once the system is back to normal after a battery disconnect etc..
Reset the alarm list also.
Open Multi RS in VictronConnect.
History Tab.
Reset History.
I want to reset it without having to reboot/shutdown anything..
Reset the history from VictronConnect as above…
Thanks, I know about that reset feature, but I guess it will reset everything including total Solar Yield since system install? I would like to keep that if possible to see how much I’ve generated since the install…
Total yield will be reset.
System yield will not.
System yield is not (easily) resetable and holds the yield since the first power-on.
Great, thanks very much! Worked as you described!
