Replacement battery for AGM 12-200
Hallo
I am looking for a very thin AGM 12-200 battery. (Deep Cycle). However, with these measures, I can only find telecom batteries. (BAT412181164). Should be replacement for a MAN TGX horse transporter.
Telecom Batt: : 546 x 125 x 323 mm
Customer Batt: 545 x 125 x 320 mm (probably measurement error)
Bye
Ive used to use Enersys Powersafe batteries, they also come in this format, 12V190F, but according to the datasheet they are 561mm long, but i guess thats including the carry handles
You will only find telecom batteries in that size, the telecom refers more to the shape, otherwise they are usually standard AGM and can be used in a horse wagon.
Many thanks for the information and for your support. :slight_smile:
