Hello everybody I’m new here.
I can’t find any information on this topic so thought I would ask here.
I have just installed an Orion XS dc-dc charger and have now decided I want to hook up a remote on/off switch on my dash. My question is what size fuse should I use in the switch circuit and is it best located close to the charger?
Thank you Greg
Depends on which option you are using from the 3 shown in the manual.
For L-H or L wiring you do not need a fuse. For H wiring you would use something to protect the wire from short circuit, it only needs to be 0.5A or so as the switch will pass micro amps.
This is not a specific Orion issue but a general wiring issue.
Thank you. I will be using L-H
