Hi.
This morning I was asked which UI I wanted when I tried to open the “remote console”.
The old or the new UI — strange, as that is normally configured.
After the usual loading, it was accessible.
Because the Wi-Fi was acting strangely, I restarted it.
Since then, I have no longer been able to access the “remote console”.
Restarting the Serbo GX and disconnecting the power twice have made no difference.
The same goes for the Wi-Fi: restarting it and disconnecting the power made no difference.
I can see the VRM “in real time”.
All values are indeed refreshed regularly.
Using the same Wi-Fi connection between the Serbo and the laptop, I can access the “remote console” after entering the address provided by the Serbo into a browser.
This address of the Serbo GX had changed after restarting it, by the way.
In other words, everything is functioning properly, but I cannot access the “remote console” via the VRM portal.
After trying to “fetch” it for a long time, I get the message “Check if your GX device and your browser have a working internet connection”.
Yet “real-time” data is being sent? (This can be seen from the moving blue snake and the accompanying message.)
