Registre Modbus ou noeud Node-Red pour ESS
Bonjour,
Je souhaite pouvoir basculer de Toutes les charges du système à Seulement les charges critiques soit en utilisant Node-Red ou un registre Modbus.
Sauf erreur, je n’ai pas trouver quel registre Modbus utiliser ni quel noeud dans la bibliothèque Victron Node-Red.
Merci d’avance de vos conseils ou infos à ce sujet.
oui pour le moment ce n’est pas possible mais j’attends aussi cette fonction !
Merci Thierry, je me doutais bien que ça manquait. :wink:
En attendant une éventuelle mise à jour avec cette fonction, je cherche un moyen !
J’ai rapidement cherché. J’ai trouvé ça:
[{"id":"8d3226f74224e6c8","type":"victron-output-custom","z":"606b655c5dab1a2b","service":"com.victronenergy.settings","path":"/Settings/CGwacs/BatteryUse","serviceObj":{"service":"com.victronenergy.settings","name":"com.victronenergy.settings"},"pathObj":{"path":"/Settings/CGwacs/BatteryUse","name":"/Settings/CGwacs/BatteryUse","type":"number","value":0},"name":"","onlyChanges":false,"x":470,"y":1880,"wires":[]},{"id":"dc38da82d66ed754","type":"victron-input-custom","z":"606b655c5dab1a2b","service":"com.victronenergy.settings","path":"/Settings/CGwacs/BatteryUse","serviceObj":{"service":"com.victronenergy.settings","name":"com.victronenergy.settings"},"pathObj":{"path":"/Settings/CGwacs/BatteryUse","name":"/Settings/CGwacs/BatteryUse","type":"number","value":0},"name":"","onlyChanges":false,"roundValues":"no","x":310,"y":1800,"wires":[[]]},{"id":"f4e3777ba11917ac","type":"inject","z":"606b655c5dab1a2b","name":"0","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":150,"y":1860,"wires":[["8d3226f74224e6c8"]]},{"id":"7f2dd8fee155ede1","type":"inject","z":"606b655c5dab1a2b","name":"1","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":150,"y":1900,"wires":[["8d3226f74224e6c8"]]}]
Parfait Quentin, merci beaucoup c’est super :+1:
Merci Quentin top
