To anyone,
Is it possible to reboot the cerbo-gx from home assistant?
Thanks!
You can enable ssh in the Cerbo and then use a shell command in HA. You have to create the ssh-keys beforehand,.
shell_command:
reboot_cerbo: ssh -i /config/.ssh/id_ed25519 -o 'StrictHostKeyChecking=no root@cerbo' /usr/sbin/reboot
small typo, you forgot the quote at the end of =no
and personnaly i used only one ssh key in HA and i prefer to use the IP instead, so i used this line :
reboot_cerbo: 'ssh root@192.168.1.xx /usr/sbin/reboot'
Thanks, corrected. The stricthostkeychecking is there to overcome the need to log in the correct container and run the ssh-command manually and accept the new hostkey.
With new gui-v2 I do believe there should be a ws://venus.local command to send to reboot a Cerbo in a way Victron is doing via UI Reboot button
Here it is
W/__your_system_id___/platform/0/Device/Reboot
Send
{"value":true}
and it should reboot.
You just need to use
creds
Thank you, it’s work like a charm, if someone need, please found my code about it :
button:
- name: Reboot Cerbo
unique_id: victron_Cerbo Reboot
object_id: victron_Cerbo Reboot
command_topic: "venus-home/W/xxxx/platform/0/Device/Reboot"
payload_press: '{"value":true}'
qos: 0
retain: false
entity_category: "config"
device_class: "restart"
icon: mdi:restart-alert
device:
identifiers: ["Victron Victron Cerbo GX"],
manufacturer: "Victron Energy",
model: "Cerbo GX",
Thank you! It works!
